HI i am new here and need help please my gl 1100 is misfiring at 3000 rpm for the firs 2km it runs perfect after that it start to give trouble if i turn the throttle more it is better from 4000-5500rpm and then bad again i cleaned the carburetors and checked the gas in all of them it is the same volume what else can be wrong
is the back fireing always on the same side ?
It is either too lean or a slide is sticking until it warms up.
Also could be the valves too tight.
I've had that problem for years. When I keep the gear selected to a higher RPM it is diminished. But when on the highway and go for more throttle sometimes it bogs down and other times reacts really well. I picture those Vacuum slides hanging up even though I've cleaned them quite a few times with no help. I can take the carbs off in 18 minutes and 32 secs now. ha ha ha
gl 1100 misfire
the valve settings are ok if i remove the screw on intake rpm drops but on one it stays the same i am stuck
I guess it still has a low speed jet plugged.
