I have just done an oil & filter change on the old 1100a, using a quite expensive Shell Helix 15-40 oil. After finishing the job, looked around and saw a spring, about an inch across in size, that fairly obviously used to be inside the filter casing. Is it important that I pull the filter out and replace the spring, or can this wait until next oil change. Thanx - Simon
