Looking for some info again... GL1100 I 1981 Model
It started with an oil leak at the fuel pump (rev counter cable). I then tried checking the oil level at the window (total [email protected]#k up as you all know) I also have a dip stick installed and I think I miss read it and I put more oil in the bike. Now I have an oil leak at I think the bottom of the dip stick where it connects to the old sump plug and it also looks like the oil is blowing out at the top of the dip stick (when at speed), it does not screw in it just plugs in.... Now my question can the oil pressure push the oil up and out of the dip stck if overfilled or what else could be the problem???
