I have owned an 83 bare wing since it's birth. It has 62k miles and has began to run as though it has a miss or bad cylinder. I have performed the obvious including a carb rebuild and sync job. I seem to be able to hear a metalic noise in the valve area but the compression is nominal @110 to115 per cyl.
Are there any suggestions our common problems I may not know about.
Thanks, Joe
Thanks, Joe
