Hi,
I was attempting to start my bike after many months. I connected my battery (I disconnect it when I do not use the bike for a while), turned on the ignition, lights came on, hit the starter button while switch was off, starter cranked.
I then pulled the choke, turned on the starter knob, and hit the button. The starter cranked but the bike did not start. Understandably, has been sitting for many months. I kept cranking in short bursts until the battery was finally dying but did not start.
So smart (dumb?) me, connected a battery tender, and continued to crank for couple of minutes, but it did not start. The black wire connected to the battery's left (negative) terminal was getting extremely hot. So I turned off the bike for a few minutes, disconnected some accessaories like running lights. And connected only the black wire from the starter to the negative and the red wire from the relay to the positive and tried once more (with the battery tender connected). Then nothing - no more cranks from the starter and a very soft click from the relay. Lights still worked.
So I then took the battery out, fully charged it, and put it back on. Cleaned my plugs, they were a little wet all seem equally dirty. Tried again. Lights works, headlight dims when I press the starter button. I get a loud click from the relay / solenoid, but no cranks from the starter.
Need some help, thanks in advance.
Regards,
Dan
Regards,
Dan
