GL1100 relay
489 Views 2 Replies 2 Participants Last post by  mcrowdus
I have a 1982 GL1100 that I found a relay while changing out my coil pack that I have no ideal what is is. The number on it is S5H-02 and it had a wire jump fron one connector to the other then it was taped to the plug, I say where someone say it is a turn signal flasher relay, but all my turn signal are LED'S and I change the turn signal to the electronic relay whic is round. so I am needing to know what this relay does before I put the bike back together. Please Help:praying:
1 - 3 of 3 Posts
your stock 82 had no relays from the factory (other than trun signal) so you may have to trace wires to find out what it is for. a quicker method is to unplug it and see what stops working.
Relay
well that is what i was thinking everytning seems to be working but I was wondering what is was for. so I guess i will put it to where I can get to it easy in case i need to make a coneection, thanks for the help:claps:
1 - 3 of 3 Posts
