Good morning, can anyone tell me how to change the valve seal on a 1982 GL1100 with out taking the heads off and if you have photes to guide you thru it.:praying:
The Irish Crew
There are a few existing threads on this. Some owners have successfully used rope stuffed into the spark plug hole to stop the valves dropping when the springs are removed. At least on thread shows a home made tool in action that does the same thing.
I havent tried this on an 1100 yet , but on many other engines , i have used my air compressor to pressurice the cylinder/head through the sparkplug hole . This pressure (around 10 bars) "holds" the valves while you are working .
Junior Grue
Perhaps you misplaced a decimal and meant one bar?:?
Unless you're Magilla Gorilla you'll not be holding a piston on TDC, which is where it needs to be with that method, at 145 PSI air pressure.
I've used the rope method several times on small engines including 1100s. It's simple especially if you don't have a compressor. All it takes is some 1/4" nylon or poly line to feed into the cylinder with the piston at the bottom of the exhaust stroke. Then turn the crankshaft so the piston pushes upward against the rope which will hold the valves up. It doesn't take much rope with an interference engine as these are. One way to keep the piston against the rope is to have the bike in gear and pull the rear wheel to bring up the piston, then tie or weight down the brake pedal.
As long as you have all the rocker arms off so all the valves are closed it doesn't matter where the piston is using that method. Use as much pressure as you want. 10 bar is more than necessary but I have done it using whatever shop air pressure was.
Junior Grue
You're correct.
I was thinking leak down testing on L-heads which I've done hundreds of.
