1 - 20 of 37 Posts
I notice that when cornering my 83 interstate tends to scrape the ground, is it the center stand (or) kick stand?
I notice it scrapes more when cornering left more than to the right.
I don't feel it in my feet so I don't think it is my footpegs.
To aleviate (or) at least minimize the scraping, I can pump up my rear shocks but then the bikes sits too high ( I have short legs - lol ) and the ride is stiff as heck.
Anyone have an idea how to remedy this and keep the bike relatively low to the ground?
I don't think it's your center stand. I have an 84 Aspencade and when I bank the bike hard sometimes the floor boards scrape. Their hinged so you really don't feel it on your feet. Look under the floor boards mine has a small bar under it that's what is scraping. I have a feeling it was engineered that way to let you know not to bank so hard.
Hope this helps.
Have you checked how much weight that you have in all of the storage??? It might be that you are pressing the limit of the shocks.:coollep:
My 82 sometimes scrapes on the left turn with wife onboard. It scrapes on the center stand as well
1987 GL1200 Interstate
It's my understanding that the GL11 had very limited cornering clearance. Honda corrected that in the GL12 by moving the engine up and forward, among other things. Never fear, they un-corrected it when they introduced the GL15, then made it worse by lowering the bike in '96. From what I've read, the 18 loses even more clearance.
Your contact point? Only you can answer that. Get under the bike and have a look. Contact with the road makes easy to see marks.
My first guess, since you said you have footpegs and not floorboards, would be the exhaust system. Probably in the rear, if you don't air the shocks up enough.
I've scrapped the center stand before once when Bagmaster and his lovely wife Linda were showing Tracy and me around their neck of the woods, Linda looked back when it happened and there I was with a sh*@ eatin' grin and Tracy on the back yelling in the intercomm to stop playing around like that:D:cheeky1::D:action:
thanks for the replies - I guess I'll get down low and take a peek at the newly scraped shiny metal and find what it is scraping.
Discussion Starter · #11 ·
lmao!!!!!!!!!!!!! no it's not that bad bro...
And is this the reason we've had so many forest fires in BC this year? :)
That pic was taken on the Dragon! Check to make sure the springs are holding your kick and center stands all the way up. They could be weak.
Bernie
on my 1200 i scrape the sides of the Marklin rear bumper. on my 1500 i have beveled the outside edges of my boots...nobody follows me with a camera...darn
On my 1100 the driver pegs will scrape first. If I hit a bump while leaning the center stand will bounce down and hit but comes right back up.
Weird if you look at your avatar gif for 5-10 seconds it seems to speed up and slow down.
You know, if you lean with the bike instead of against it you can corner without scraping so much.
I have an idea of how you can keep the shocks aired up and still sit lower if you are interested. All you have to do is cut the bottom of your seatpan out which will allow you sit almost 2 1/2" lower. I posted about it here while back. it not only lowers your body down, but allows your sitting bones to make proper contact when you sit down as well.
The one thing I found that usally stops mine from scraping,is a good smack to the back of the head from the wife.......:D:D:D:Dusally works everytime for me..
same here!!!:D:D:D:D
1 - 20 of 37 Posts
