I recently had to replace my clutch cable. It has been hard getting things adjusted correctly. At first I was experiencing clutch slipping. I got that adjusted out and everything was fine.
Now I am experiencing a problem shifting. I disengage the clutch and step down on the heel toe shifter and it does not go completely in to gear. Then pops out and is basically like it is in neutral.
If I slow down and disengage the clutch again and kind of stomp on the shifter it will usually engage and be fine but sometimes it just doesn't want to engage the gear at all . It seems to be worst in 4th gear.
Adjusting the clutch either way doesn't seem to help.
I'm not sure if I have a clutch problem or a transmission problem. Or both!
HELP!!
:hovering:
HELP!!
:hovering:
