chskbak wrote:
You're on the right track. My guess is that main fuse.
i went out to start the bike for work this morning, she is always a little cold hearted on a cold morning, started out turning over just fine, but before it started somthing clicked and everything went dead, i did not have time to look at it so i jumped in the truck and headed into work, i will be working on it after work, main fuse, starter relay, battery connection, not sure what to look at after those are checked any idea's
Yep, I have done that anyway! But this was about the "+" wire contact at the battery, the leaden clamp got oxidized andcaused troubles with contactwhen a lot of "juice" comes thru, like when starting....Clean ground battery/frame even if you have another problem.
