I have the front wheel off to mount a new tire so I thought I would clean and regrease the speedo drive. I have the drive unit off and the drive gear out. But I don't know how to remove the worm gear.
Any suggestions?
Brian
I just swab out the old grease with a rag and a thin screwdriver. Then repack it with fresh hi temp wheel bearing grease. Not really a need to remove the worm gear unless it's broke.
I don't think that you can remove the worm gear... I normally just spray-clean it, then repack with grease.
BTW, be sparing with the grease, as any excess will fling out onto your left brake rotor.
I don't know what wing you are referring to BUT on my 93SE a too thick of a grease will sieze the gear. Been there done that. I used a sewing machine oil on the gear and dri slide on the cable.
The Irish Crew
A wash out with WD40 first and a small bit of grease will do no harm. What Goldwing model are you referring to Brian? It helps to know that when we are dealing with tech questions.
Sorry, I am resurrecting a '82 GL1100 Standard.
I took all your advise and cleaned the worm gear in place, put a small amount of grease on the teeth of the big gear and the inside running surface and have it back together.
Thanks for the help
Brian
