1 - 17 of 17 Posts
Is it normal for Wings to stand up straighter than other bikes when on the kickstand? I wish it would lean a little more since it seems that it wouldn't take much for it to tip over on the the other side. :brokedown:
you probably need new springs in your rear shocks. Mine did that until I rebuilt the shocks with progressive springs. Also how much air are you running in the rear shocks? With the new progressive springs, I can ride with no air and not bottom out and the angle on the side stand is so great that I use a piece of 1/2 plywood when she is parked in the shed.
I run the high end of the recommended air pressure. I will probably do the spring thing..
Pete
Do you have a chrome big foot kickstand on it? If so, they are made too long.
Bob Cassel
I always worried about my 82 GL1100 I falling over, the wrong way, when I put her on the stand. So I always "lifted" her when I got off.
Then I put new springs in the rear. NO PROBLEM NOW.
Do the springs, most importantly the rears. I'm doing my fronts soon.
I just have the stock kickstand. When you talk about replacing the spring, are you replacing just the spring part of the rear shock or are you replacing the shock as a whole?
bike will stand strait when the front shocks air low on air to... Just to let you know. might be front and not back.
Bob Cassel
Shocks on both the front and rear are re-buildable, including the springs. Over time, the springs will collapse and that is what happened on mine. For about $50 I put new Progressive Suspension brand rear springs in. Made a world of difference. When I get a spare 100 buck, I'll do the fronts.
Vintage Rider
My '85 LTD has what I believe are the original shocks/forks, neither has ever been rebuilt, and neither holds air. The bike sits fine on the sidestand, but is very mushy on the road, I have banged the centerstand in corners while not leaned over very far.
I was looking at replacing the stock rear air shocks with Progressive non air shocks (I do not want or need air shocks) They cost $214. Is it possible to put strong enough springs in the stock shocks that they would not need air? It would be a lot cheaper that way, but they would need to be pretty strong springs.
mine stands at attention too i run high air psi in the rear shocks
Discussion Starter · #11 ·
How much psi do you run? I put in more when my wife and I ride two up.:kissing:
I don't know how accurate my gauge is so I could be a little high...however, it would seem to me that higher psi would make the bike lean more, not stand up higher on the kickstand.
probably 70psi been doing yhat for years ill invest in a new set of shocks if they blow up
Discussion Starter · #13 ·
Maybe I'll up it some. Probably not that high, but the recommended dose never seemed to be enough...at 6'3" 260lbs, I tend to give them a work out.
ok -- now we have the whole pic. yes the springs are tired . from what i read , progressive springs front and rear should clear up the problem your having and help with a lot better ride and control in the twistes . give progressive a call and they can recommend a spring rate for your weight and such. both front and rear. have fun , its a great handling bike for touring when set up right.
Discussion Starter · #15 ·
Actually, I had the wrong psi in the rears. Not sure where I got my numbers from...may have seen the tire pressure number which was listed on the next line, but I only had about 30psi in the rears. (doh)...saw that 57psi was on the top end so I put about 60 in and that made the difference. Don't bottom out anymore.:applause:
ive never had any issues with mine running alittle higher psi im sure someday the seals will go but im not dropping 200-400 on shocks right now
It would be a shame to put spring shocks in a LTD/SEI. The autoleveling feature is pretty handy when riding solo then two up. You can get stronger springs from Progressive to install in your OEM shocks for around $50. They will make a considerable improvement in the bike's suspension.
1 - 17 of 17 Posts
