I think my starter clutch is stuck. I was cranking on her after installing my single carb conversion and she would crank crank crank and then stop. release the button and crank crank crank and stop. did this twice and the last time it would not crank anymore. The starter seems to spin only. I have taken the starter off and without bench testing it, it is tight and spins. there is not any debris in the bottom where the starter mounts. The chain has tension one way and free spins the other way. With the bike in gear and the clutch pulled in, the bike is very difficult to roll. With the bike in neutral, the bike rolls freely. I have put the bike in gear and rocked her back and forth to no avail. The starter just spins. I am not sure, but I think the starter on these bikes does not kick out, it simply spins when you push the start button and turns the starter clutch with the chain. Is that correct?
What are my options. I have just installed the single carb, so it will be a dry start on a pull start.
