GL1100 Starter Problems
520 Views 2 Replies 2 Participants Last post by  frankenpak
It will not turn over, off the bike or on the bike. I took it apart twice, can't find anything.:?
1 - 3 of 3 Posts
take it back apart and see if the field wire is still connected to the lug that the battery cable hooks to . if you check it when apart with a ohm meter it should show a open.
I will do that tomorrow.....I did find that the wire in the very back of the armature is missing some insulation, also that same wire has a end that can be bent, is that suposed to touch the back of the brush cover plate to make a connection ???? I will re examine everything tomorrow, something is not making a connection. Thank's
1 - 3 of 3 Posts
