I was tidying up the wiring going to the starter relay and pulled the 4 pin plug from its socket. I then found it was not a plug but a plastic cover for 4 spade tipped wires.
The cover fell off and now I don't know which wire goes where.
Can someone help with specific directions as to which terminal each wire goes to?
I have a red, a red-white, a red-green and a red-yellow wire. Here is a photo of my start relay showing the 4 spade terminals.
Thank you for your help.
I don't have a 1100 to look at but looking at the wiring diagram here is what I find.
R and RW go to two of the terminals that appear to be tied together. One goes to the switch and the other to the voltage regulator.
G/R goes back to the clutch and is the ground side.
Y/R goes to the start button and provides 12v to operate to relay.
You should be able to read some resistance between two of the terminals. This will be the coil winding to operate the relay. Connect the G/R and Y/R to these.
Maybe this will help.
Thanks for the quick reply, Larry
I have the wiring diagrams, but don't have an ohm meter to take readings.
I was hoping someone would reply and say the red wire goes on the top left terminal in your photo, etc.
Thanks again. In the meantime, I waiting for the above person to answer
Ted
Looking at my 83 I see slightly different colours - or they're terribly faded. And your relay looks to be an aftermarket replacement.
Looking at your picture:
Top left - heavy gauge red/white Top right - heavy gauge red
Bottom left - white/red Bottom right - green
Thanks GIDO
that's what I was looking for. I just needed where the heavy gauge red and red/white wires went. The other two are the coil
Mine are a yellow with a red stripe and green with a red stripe and that's what is on the wiring diagram. Your yellow wire might have faded and looked white.
Thanks again and hopefully I can get my sweetheart running again.
Ted (from Ontario)
It it helps at all I have the same solenoid and my wire are
top left red/white top right red bottom left yellow bottom right green
good luck Bo
Hi Guys
Plugged the wires in like you said and away it went.
New starter turns it over FAST !
Thanks all you guys for all the help. This is an amazing forum!
:applause:
