1 - 9 of 9 Posts
So I'm looking and doing research for a new stator for the 82 1100I and I'm curious for everyone's opionion on new stators. I know of several sites that offer updated/rebuilt/new stators for these bikes, and I need to replace mine and would prefer something with more power. So who's the best?
Poorboy's alternator conversion!
Bernie
Isn't the Poorboy conversion just for the 1200?
If you want to keep the stator, just take it to a local electric motor repair shop. If they can't rewind it, then they should know who does. Mine was around $120 CND.
James
I put an electro sport in mine and have about 3000 miles on it so far and no problems. It is suspose to put out 20% more power than stock. Dwight
the poorboy idea should work on the 1100 just depending if your good at making the brackets because the kits brackets want work. i saw one on here not to long ago but it was on the right side and hung way out. you should be able to get it tucked in some if you don't mind grinding on the atl housing want hurt it and you should be able to mod the fan so it will fit on the left side. i have an 1100 setting here and it looks almost the same you'll just have to improvize. would be well worth it for the extra amps. mines putting out 67amps.but if your not creative pull the engine.:cool:
1 - 9 of 9 Posts
