I have a 83 GL 1100 and at idle the tach jumps around. The carbs are synced and she seem to have a slight roll at idle, any help on this? Could it be the idle mixture adjustments they are set a three turns out now.
Chowdave
It could be the tach cable itself.Unless you can hear the engine change rpm.A rusty cable will cause eratic movement of the needle.
Defo the cable. I have the same problem.
My original cable broke and I didn't have any movement. I changed it for a new one but didn't route it properly and now get the bouncing. Going to replace again.
Senior Something
I believe the starting position for the pilot screws is 1 1/4 out
Might try fiddling with those.
