i have spent several hours trying to install a set of timing belts on my gl1100.i don't know where i going wrong,but i am.when turning crank to tdc do you turn 2 rev'd to move cams 1 revoution. it takes 2 times by t-1 to move it 360 degrees i think i've got the valve adjusting down pat,buti believe my timing belts are not right.i must be one dummy cause i can't get it right.everybody seems to thinks it easy. i really must be at the place in my life where i should just let a shop do it,hard on a retired person.i have printed three sets of instructions off our site.i did note that when number 1 piston was at top the number 2 piston is at top on my gl1100.the instructions look fairly easy,but somehow i make a wrong turn,help. thanks hoghideman
