sle104 wrote:
The cracks can be repaired using ABS cement then sand and paint
I have found that by trying to repair cracks that way they always come back. To repair the cracks, you will need to repaint the entire part anyway. Is it bad enough to need repair? If you want to really repair it right, take a Dremel with a cutoff wheel, and cut through the cracks lengthwise, basically turning them into cuts rather than cracks. That alone will strengthen the surrounding area, and prevent the cracks from spreading. Now you will need to fill the area where you made the cuts. Clean the back side of the lid good with lacquer thinner, then use some fiberglass tape and automotive Bondo, and glue the tape to the underside of the trunk lid with bondo. The fiberglass tape is for reinforcement. Hopefuly when you did this, some of the bondo pushed through the cuts, and is sticking above the surrounding area. When it is dry, sand it down smooth. Add more bondo and sand again if necessary. In order for the repair to last, you need surface area for the bondo to adhere to. The thickness of the ABS plastic where you made the cuts is what provides this surface area.
Another much simpler way is to simply use chrome washers between the rack and trunk lid big enough to cover the cracks.
When I cleaned up my LTD, and got rid of all the junk I didn't want, it left 18 holes in the trunk and lid, mostly the lid. I removed speakers, armrests, and a handle of some kind. I simply got 18 1/4" carriage bolts, popped them into the holes, they snapped right in and centered perfectly, then I used nuts and washers on the inside to hold them in place. It should be a nice clean look when I paint it.
