1 - 3 of 3 Posts
i bought this bike 2 months ago since then i replaced timing belts new tires and went through the carbs cleaned and synced iv been getting 42mpg and it runs great the only problem is when i let up on the throtle fast i smell rich exaust i dont know mabe normal for this bike its a 1981 gl1100 28000 miles
If you are getting 42 MPG can't be much wrong but the air cut off valves may be stuck which may or may not cause backfire on decel.
Piled Higher and Deeper
DaveO430 wrote:
... but the air cut off valves may be stuck ...
+1 or no good and leaking.. were they in good shape when you cleaned the carbs??? Mine were porous.. you could see through spots (it is a rubber covered fabric)
1 - 3 of 3 Posts
