The air lines on my 1982 Aspencade are rotten and I am not sure that the compressor will even ride correctly on the breather of my single, solex knock-off carb. What options are out there for either making the Air Shocks manual fill or going to non-air. Thank you for your advice.
ebay used hose sets.
Official "Cheeky Plonker"
I use a Weber 32/32 DFT, I'm told it's also a knock off, but for $95 who's complaining? I use the slimmer 3/4" air filter so that the compressor tubes don't interfere.
The only problem I had with room under there was when I swapped out the fuse box for an auto fuse box. And there's a fix for that too, if you run the fairing.
But if you really want to reverse engineer it, try any of the above. They will all work.
