First post here, first Honda. New to me 84 Aspencade. Long list of restoration/maintenance catch up stuff I am doing but finally got to pull the carbs. My question to the experts today is... the plastic "air box cover" is partially melted and I have only a couple guesses why; can anyone shed some light on this?
Started it up for the first time after it had been sitting for several years. Ran like crap as expected with a bunch of Seafoam in the tank and I expect crud in the carbs (but it runs so my $500 investment was not so foolish!). After running on the stand for a couple minutes there was a puddle of fuel under the bike. The whole area under the carbs was wet so I couldn't isolate the problem and I have been reluctant to try and duplicate the experiment. Upon removing the carbs I noticed the melted cover (corner closest to the right front carb), and the outside of that carb covered in what looks like "dryed fuel shellac". In addition, the inside of the airbox is REALLY dirty and a thin layer of the same brown crud. The screens are dark brown.
My theories
Also, does anyone know a good source for a replacement part? I have checked 6 or 10 online parts houses with zero available.
I would obviously like to nail this down before I get her back on the road. The idea of a major gasoline fire between my legs doesn't sound like fun :/
My theories
- could this all be from bad backfire? Air cut valve replacement to the rescue?
- could the right front carb have an issue that would cause it leak into the airbox? Stuck float?
- the tracking device implanted by aliens is causing a fuel feedback loop?
