Well now that I got through with the carb balancing, I have started to check out the air compressor system to see why it does not work. So far all the fuses are ok but I don’t know which one is for the compressor? I’m thinking that since the bike has set so long that the compressor is froze up or jammed some how? My problem at the moment is I can’t find the air compressor, I know that sounds dumb but I need some input on the location, Oh by the way this is an 85 1200
Tom
Remove the right hand glove box and you'll see it. It's mounted right behind the control buttons for the air shocks.
Oh Wow,.....the one place I didn't look! I was beginning to think it was missing.
Thanks for the info
I think the ignition key has to be in the parked position also to activate the compressor switch. :action:
The Irish Crew
If it's the air outlet you mean, the ignition has to be in park for it to work.
