GL1200 air in suspension (front)
732 Views 2 Replies 3 Participants Last post by  DaveO430
hi.. guys i need some imormation ... when i put my small compressor onto the valve at top of forks and add air as soon as you pull it of it looses its air with only a small amount being put in 6 psi.. is there any way round this or what am i doing wrong... or do i need a special adapter.... when i am doing the rear this is ok because..if i put 40 psi in when i take it of it looses 5 psi this is ok because i want 35psi in rear.. you guys will now what i mean....... regards.... jim:waving::waving:
1 - 3 of 3 Posts
I hear ya - I just guess. I just try a few times until it feels right, then leave it alone.
there is such a small volume of air in the forks that even checking the pressure with a gauge releases a couple of PSI. You have to overpressure them and then use the gauge to release small amounts to get it right.
1 - 3 of 3 Posts
