1 - 9 of 9 Posts
Battery not charging. Voltage not increasing to battery. Checked output leads on alternator and getting low output voltage. (1.4vdc) Should this be checked in a/c instead? If it is bad this would be the 2nd alternator in 5 years. Other one was from bad connections. This one is now soldered. Was working fine before putting bike away for winter. Battery was totally dead this spring though. Put a brief charge on it then jumped from car to get running. Run fine for about 2 miles then died from no input to battery. Sure hope I don't have to pull motor again and again and again if I can not find ongoing problem. It's time to ride in Western Pennsylvania!!!
should be checking for ac voltage from stator. have you considered the poor boy conversion?
I agree with trashtruck. Should be 50 to 55 volts AC at the three wires. Any and all 3 wires wire to ground at about 2,000 RPM. Poorboy is a good idea if failed.
Loyal member
The poorboy is the way to go,not to difficult to install and all the voltage you'll ever need.P.S. if the alt goes bad it's a half hour job for replacement.
have you checked for good/bad connections at the regulator and also the solenoid?
Need to recheck
It is an aftermarket I believe. I need to check the voltage the proper way to be sure it isn't anything else. I hope it is. Looks like that poorboy is a possibility though. I will get back and let you all know how I made out. Thanks for the responses.
1 - 9 of 9 Posts
