1 - 2 of 2 Posts
Hi i checked out the older posts on replacing the main fuse with a mini fuse and holder great info however i have 4 spades and just wondering should i dremel the outer two spades and plastic off, the older post dosent mention this, any info on this would be great! and Thanks!:?
Leave the spades alone on the solenoid. If you are just replacing the main fuse connect the wires for your fuse holder to the screws that held the dogbone fuse. If the spades are burned where the wires connect cut off the terminals on the red and red/white wires and solder one end of the fuse holder to those and connect the other end to the + battery terminal or the terminal on the solenoid where the battery connects.
1 - 2 of 2 Posts
