Hi, just a quick post that I hope helps other un-technical GL1200 1984 owners like myself! Bike suddenly cut out, luckily when turning into drive. Brake lights working and appear to be permanently on, all fuses OK. Not looking forward to wiring fault diagnosis when remembered post in another forum. Check that your rear brake adjustment wiring is OK, this part picks up all sorts of dirt and oil. Checked mine, and sure enough it wasn't allowing brake circuit to switch off - hence the problem. Manually operated it and all brake light circuits worked ok. Intend to clean it all up tomorrow but felt much more relaxed now! Thought worth a quick post just in case it helps someone else before they worry that they've got a major electrical problem.
Ben (UK)
Ben (UK)
