I have recently bought a GL1200 aspencade which i have found out to be a california model (being amateur mechanic makes it a bit more difficult!) it has sat for 3 yrs so i put clean fuel in and a new battery and fired it up an she started but she was rough, she was missing a cylinder or possibly two?? so i removed the carbs and cleaned them and they are ready to go back on but something tells me that this wont solve the problem. when she ran for the first time before clean carbs there was fuel coming from the valve by the fuel fill up cap and it was running into the drip tray, it was quite a flow (if you dont have a CA model you wont have this valve at least i dont think?) the valve is connected to a vacuum canister just to the rear of the fuel pump and it also connects to both rear carbs by some tubes. now im hoping that the carbs were blocked and they were over flowing and forcing this fuel up but if not then could there be some thing else wrong?? any advice would be much appreciated
Thanks Ali
Thanks Ali
