1 - 12 of 12 Posts
I am having a hard time shifting my GL 1200, 1985 Aspencade at times. I know the book says it can mean there is air in the lines if it happens when warm. It does get worse when warm, but sometimes it works fine.
Also, I looked at the fluid. It is pretty brown in the master cylinder. Should I try to clean that out, or flush it all through? How clear should that liquid be if it has been in there for more than 3 years (maybe way more?). Is there an easy way to clean it out without removing the master cylinder?
Any advice on this? Thanks!!
Vacuum the old fluid out with a turkey baster... swab out any remaining grunge and dirt being careful not to knock out the little clip at the bottom, refresh with clean fluid, open the bleed valve on the caliper and bleed the old fluid out being careful not to allow air in the system.
Speed bleeders come in handy for that job :)
I used a mity vac to clean it out then filled up the resivoir and kept it filled with fresh fluid then opened the bleeders and used the mity vac on them and it all worked like a champ. I did the clutch and front and rear brakes together. Used dot four synthetic fluid.
Isn't synthetics a No No?? DOT 4 yes, but thats not synthetic, DOT 4.1 is, but don't use that.
That was my understanding, Am I wrong..?
My book, if I remember right, says not DOT 5 synthetic. I'm not sure about DOT 4 synthetic.
Thanks for the info!
What I used was Castrol synthetic brake fluid. I have the bottle at home so I don't know if it was dot four or five or whatever but it was synthetic.
Don't know why it would say that. All it does is not attract moisture like non synthetic does. I've had it in my VTX since it was new and I changed it.
1987 GL1200 Interstate
VTX is correct. That's the best way to clean out and bleed the system, and it should be done every couple of years.
He is also correct about the brake fluid. Synthetic is fine, and it's easier on the paint.
However, I can not condone his ownership of a VTX. ;-)
AHHHHH, jealousy will get you no where!!!!!!!!!;)
tricky wrote:
Obviously if you don't want to waste money on a mighty vac.... use step one
Some might say a waste others an investment. If you really want to save a buck I have used a piece of plastic tubing on the bleeder and made sure it was in a container with fluid in it and open the bleeder and just make sure the reservoirs and the container keep fluid in them. Two pennies.
I have been bleeding brakes on my 84 & 85 wings since 84, I do them every two years.
Probably spent the equivalent of a mightyvac on fluid in that time.
Sure if your doing bikes every day they would be worth it, but a $1 in a dollar store for a turkey baster, so long as you dont use it for a turkey I find it fine. Now I saved the money on the baster and use speed bleeders.
Oh yes, if those sight glasses are starting to yellow you can always visit here:
http://newrivercyclesalvage.com/sight-glass.html
1 - 12 of 12 Posts
