Just a line that might help someone.
My 1986 GL1200 Interstate sprung a leak on the lower flex tube of the clutch hose. The OEM part has a centre rigid section and two flexes, one to the lever and one to the slave cylinder. The lower flex is crimped to the rigid so, a two part assembly. I could not get a replacement either in a timely manner or that was not as old as mine.
Plan A
To cut the lower hose off the rigid, re flare it and hunt up (or make) a short M10 Banjo x fitting hose to replace the leaker.
Plan B
Buy a 70" M10 banjo x M10 banjo flex stainless braid hose and replace the whole thing.
$25 dollars later and 5 hours labour I have a shiny new hose from lever to slave. It is a fiddle to do especially the clip below the coils but I was able to fit some of the OEM rubber protectors to the new hose to use the existing clips. I took some extra time to route the new hose inboard of the drive shaft which tidies up that area. My hose came with a protective spring on one (the lower) end and additional clear tube that I located at the headstock. It all looks neat and is a step up from bulgey old rubber. The 70" length is essential, there is nowhere to hide excess and important to follow the OEM route.
Good luck.
Good job. I always thought it would be best and way easier to do that instead of trying to replace the OE hose.
  • Like
Reactions: limpy45
Plan A
Plan B
Good luck.
If you don’t mind, where did you get the line from?
Let me know what you come up with. Now I've seen the clutch line I realise the brakes can't be far behind!
If it is of use, the threaded ends are M10X1.0. I have not looked properly but the R front line goes to rigid at the yoke, I would prefer to go to the bar with banjo x banjo then it is all new and one less joint. I can't imagine how much deconstruction is needed for the rear!
