GL1200 Clutch
510 Views 2 Replies 2 Participants Last post by  Michael5140
I have now had my GW for about 4 months and I noticed to day that the clutch is acting up. The catch point on it is right off the handle. You can not relax on it at all or it engages. How do you adjust it and what type of fluid goes into that system? Is this the kind of thing that a newbie GW qwner like me can do?
Thanks.:gunhead:
1 - 3 of 3 Posts
The clutch takes dot 4 brake fluid. Take the cover off the reservior (left handle bar)and check the level. The sight window may be discolored. If the fluid is dark it will need to be changed. Mine had a bunch of gunk in the bottom of the reservior that needed to be removed, then new fluid and things loostened right up. There are lots of threads on clutch work here. Remember to not get dot 4 on your plastic or paint, or you'll need new plastic and paint.
Here's a cool way to bleed the system
http://www.goldwingfacts.com/forums/view_topic.php?id=49544&forum_id=1&highlight=clutch+fluid+
Thanks for the help.
1 - 3 of 3 Posts
