Hi Wingers,
I am new to my 1984 Aspencade.. And I have a newbie question...
What 'should' happen when I press the 'increase' / 'decrease' buttons to adjust my front and rear air shocks?
I expected to hear the sound of an air compressor pumping air... and a gratifying feel of the bike raising slightly... however, I don't get either.
The 'Pump' only button that seems to provide air externally works. If I put the bike and set the fork lock... I can hear the air compressor working. BUT, when I just use the increase / decrease buttons ... nothing.
ACTUALLY. On the Front shocks... I can see that the LCD console changes to show the air pressure. But, with the rear buttons I don't even get the LCD display.
Is there a trick or something to make the shocks pump up?
- Craig
Did you push the front or rear with the increase or decrease at the same time?
I don't have a 1200 but the 1100 and 1500 have to do the same.
It's in the owners manual on how to do it.
should work correctly with key on,front or rear button pressed.then the compressor button
note:correct way to adjust pressure is on the centerstand
