Thanks Budd,Had the same problem with my 84 aspy was a bad ignition switch. There is a recall out there on the 84 if you look up under fairing and the bottom of your ignition switch is just a black plastic bottom like a cup. There are 3 small tabs that hold the bottom of the switch cover to the body.The fixed one has small nuts holding the caps on now. This will tell you if it has been replaced by recall or not. Also if you take your vin# to honda dealer have them run it and make sure they do it as some will not.also try to start your bike then wiggle the wire harness going to ignition switch,if bike cuts out you found your problem. Hal
I agree completely Ken,I will certainly ask the question.I believe it was a safety recall so your dealer should be obligated to replace the switch free of charge if it's still the origanal.
I could be wrong of course, it's happened once or twenty-nine times but it's still worth looking into.
