I posted here a while back and got a lot of help, and now that I’ve come upon a lot of extra time I kicked this project back into gear. I originally bought 3/4 of a 84 gl1200 for $50 almost every wire, fluid line and hydraulic line was cut for no odd reason. I pulled the engine and scraped together all the running components and tried to turn it over for the first time today. Starter works perfect and I have good compression BUT there are these two ports in the lower air box (plenum?) between the two mesh domes covering the air inlets to the carb that blast a ton of gas into the lower air box till it pool up. Pretty sure it’s not normal and pretty sure if I run the fuel pump any longer it will flood the engine.
-Thanks A
-Thanks A
