All,
My bike has only 92K miles on it and has all new Progressive Suspension springs (front and back). Tires are nearly new as well.
It has great straight-line stability, but it seems to “fall” into corners. By that I mean that once I initiate a turn by counter steering, I have to then immediately counter steer slightly in the opposite direction to keep the bike on line in the curve and prevent it from over steering way too far into the corner.
This just feels wrong to me. Seems to me that once leaned into the curve there should be no need to counter steer out of it, unless of course the curve radius changes while you are still in the curve.
Since I suspected the steering head bearings, I checked the force required to turn the handle bars with the front wheel off of the ground, and that’s in spec. There does not seem to be any lateral play in the forks with the front end off the ground either. So, I’m out of ideas.
Anyone else notice this symptom on their GL1200, or other Goldwing for that matter?
What else might be causing this? Or is it all in my head!
Any suggestions are welcome!
All,
