So first let me say hello to everyone. I'm new to the board and a somewhat new Wing owner and GWRRA member. So "Hello all"!
My issue today has to do with the installation of the final drive on my 1200. I swapped the final drive from a second 1200 (same year 84') that I have for parts.
I installed the drive reattached everything and started her up while she is still on the lift. Problem is....the wheel is not spinning. I shut the engine off and rotated the tire by hand. Sound like it is grinding inside the shaft.
So a little background on my issue and what exactly I did;
I was getting a clunking sound when I would release the clutch in first gear. This would happen only when starting from a dead stop. I took the wing to a local Indy guy with alot of wing experience and be rode it and lifted it and said it was for sure the final drive. Likely a worn bearing inside the drive. So since I had a spare bike I thought I would give it a stab.
So I tore down the rear end, removed the brake, brake pads (replaced those as well) and removed the tire and disconnected the four bolts on the housing for the final drive and pulled it out.
I then took the donor final drive (used moly on all the areas that looked like they required it) and slipped it back into the housing. I then reinstalled the four bolts, reattached the tire, brake and axle. Gave it a start and here I . No spinning tire
Did I miss something simple or do I need to tear it down again? Any ideas or suggestions? They would be appreciated! Thanks in advance!
