Pulled rear wheel off to replace tire. Splines were not only dry, but rusted. So, called local Honda place to see if they had Moly60. Was told "We don't carry that". So, what do you use on the splines then? "Just a water proof grease". I had some Primrose Lubri-Plate with Moly D that promised no melting and resistant to heat and pressure so I put that on. I subsequently located Moly60 at an independent shop but only after putting everything back together. Will use it next tire change. I did put Ride-On in the rear tire and it rides really smooth. New tire and rear end service makes a big difference. I am coming to realize that the PO wasn't much for routine service and pretty much just put gas in the bike.
