If the final drive flange on the wheel is worn, then the splines on the final drive gearcase are probably about the same. Replacing just the wheel flange with a really good one will tighten things up a little and probably give you a little more life out of it, and more time to search for a replacement gearcase.
There is more. If the final drive flange is worn that bad at 55,000 miles, it is a definite indication of a serious lack of maintenance. Pull the final drive gearcase, pull back the rubber swingarm boot, and check the splines on the front end of the driveshaft, both sides of the U jount, and most of all, on the output shaft of the transmission. A worn out output shaft is bad news. And if nobody could even put grease on the wheel flange, I doubt the pulled the entire final drive apart. I lucked out in that department, all my splines looked new on my '85 at 93,000 miles, and I was all happy about that. Until the right rear wheel bearing fell out of the wheel. Some '83,'84, and '85 models had defective rear wheels and the bearings did not fit tight enough. It would eventually spin in the wheel, wearing the recess in the hub out even bigger. These wheels can be repaired, but only if you can find a machine shop willing to do it. I couldn't. But I got lucky again. A local member of this forum donated me a rear wheel and the driven flange. This flange was also in perfect condition. As it turned out, this wheel was an '86 or '87. The hub is much larger in diameter than the '85 wheel, and the flanges are not interchangeable.
So if you take it apart, also check your wheel bearing on the right side (flange side).
