1 - 11 of 11 Posts
Hi All
Can anyone tell me if the flat style footpegs from a 1200 will fit an 1100
The 83 model had what appears to be the same pegs as the 1200 but the part nos are different
Many thanks Rob
Good morning Rob (in UK), just to clarify, do you mean "standard" pegs, front or rear?...or aftermarket floorboards?
Cheers,
Peter.
Cheers,
Peter.
Standard rubber pegs on the front
The ones I have are more like a piece of round pipe about 2" in dia but the later ones are more of a flat profile and I think they might be a bit more comfortable for a long run
I have a chance of a set from a 1200
The mounting brackets are different.
But if you can find some 83 Apsy front pegs they are flatter and wider.
I was hoping that the 1200 pegs were the same and could be fitted on my 1100 brackets
just an update
i got the 1200 pegs and indeed the brackets are wrong but then I thought that I could just take the footpegs off the brackets and mount them in the 1100 brackets as the mount idea is the same, wrong, almost there but not quite (stop too short and 1100 bracket has a back on it that catches) so then I just took the rubber part off the mount bar and lo and behold that is the same on both brackets so they are on and it will be interesting when I go to France next week
so-- you took them apart and discarded the mounts and mounted the flat pegs to the 1100 mounts , right?
Discussion Starter #10
In the end all I did was remove the bolt out of the bottom of the rubbers and swapped the rubbers on the support stems and replaced the bolts
thanks , think i`ll give that try. now to find some 1200 foot pegs.
1 - 11 of 11 Posts
