1 - 3 of 3 Posts
Hey guys, so my 85 interstate has been having some lock up issues with the front left brake, I rebuilt the master and now am working on the caliper..but when I got the kit..wow! huge difference.
The pistons that are out of my left front are 32mm and the seals I got are way small.
As you can see in the photo..the size is alot.
I don't have anything to compare too..so im not sure if someone had changed the caliper at some point?
Junior Grue
32mm is the correct piston size for the left front caliper.
I believe the front right pistons are 25mm but those seals appear to be about 20mm.:shock:
The scary part is that K&L lists three different kits when there should only be two as the front left is identical to the rear.
Sometimes it pays to get OEM parts from the dealer even if you pay a few dollars more.
1 - 3 of 3 Posts
