21 - 22 of 22 Posts
I'm restoring a 1984 GL1200i and am trying to get it started. I had the tank out and cleaned. The fuel pump checks out OK but I can't get it to pump. When I push the start button I don't hear the pump making any noise and don't feel any vibration from the pump. Does this mean the relay is bad and I should replace it?
Thomas, look right by the gas cap thats where the fuel pump is plugged in. pull that plug apart one wire is hot one is cold use your test light to see if you have 12 volt coming from the bike to the fuel pump. should light up when cranking engine with starter button, or when bike is running only. no voltage when not running
21 - 22 of 22 Posts
