Banned
My freind has a 1200 goldwing.the rear blinkers stoped working.we were working on the problem and when we went to the fuse box it was hot to touch.the major heat was comimg from the middle of the box.what could be wrong???? PLease help
mowerdoc wrote:
sounds like a bad connection on fuse box
Exactly, a loose or corroded connection creates heat.
I seen that happen on a friends 1500. You need to check the back of the fuse box as soon as possible before something goes up in flames.
If you can get it off and turned around to see the back without disconnecting everything , look for heat damage and repair as required. You could wash it down with water and baking soda to remove the corrosion . If you find loose or heated female connectors dont just recrimp them as they are now very weak , you must replace them.
