· Registered
I took my headlight apart again today because I still cant get the high beam to work. I noticed that there was a ring shaped plug that plugged into the bikes plug for the headlight then that additional plug went into the light bulb. Once I unplugged the added plug spacer from between the headlight and the bikes plug the high and low beam both work now. Any one know if I needed that extra plug? It seems to stop the high beam from coming on? Is it an add on to make the head light blink while driving?
Ron, a picture would be terriffic but as a guess, it sounds like a headlight modulator.
· Still Learning
agreed on it being a modulator, just remove it and plug direct to bulb to test. If it works you know it isn't working.
