my question is will the leaders from an 1100 swap over to a 1200? or even just the head pipes? A second question would be the 1200 went over to hydraulic valve lifters is this really an improvement to the 1100's solid/adjustable lifters? Thinking about picking up a 84 1200 Interstate, already have a 80 1100 with vetter 3 with lowers........
#1 -
The header pipes will bolt up to the heads yes. Rear mounts for mufflers and clearance may be different.
#2 -
No more need to adjust them as on the 1100 is the purpose for them.
1100 exhaust is made in one piece, the mufflers do not separate from the headers.
I prefer the solid lifters, no worries about a collapsed hydraulic adjuster, not that it happens much. Adjusting valves is not that much trouble and doesn't need to be done very often either.
