1 - 14 of 14 Posts
changed bulb and checked the fuses head light still not working any other reason the headlight would not work. Suggestions?
Hi low switch might be dirty. Open it up, 3 screws under neath switch, and spray in Electrical contact cleaner several times and keep working the switch(power off). Let dry a few minutes then try it.
Be sure and protect the painted surfaces from spray.
Start switch, try flicking it a few times.
+1 on the starter button. I have cleaned my switches without taking them apart...and definitly protect the finish with a towel.
yes. +1 on the starter button. The starter button will disengage the headlight while starting the bike.
"The starter button will disengage the headlight while starting the bike."
I learn something new every day I visit!!! Damn this is fun!!!
:applause: Awsome, I just pushed the start button once or twice and the light came on. Thanks for the tip MustangMike
Don't you just love the quick fixes and the knowledge base of the Wingers here??? :claps:
Senior Mem & Story Teller
Yeah, but none have given the correct set of numbers to win the MegaMillions lottery. (before they were drawn that is)
but then again none of us has won either
1987 GL1200 Interstate
If it keeps happening, you will need to remove the switch, possibly take it apart, to clean it.
What, you mean you missed that post? :cheesygrin:
Thank you!
Took a quick run over to the post office, and as I pulled in, I noticed I didn't have a headlight. Flicked switch from high to low... nothing, checked fuses when I got home... all good.
Thankfully this popped right up near the top of my search results.
Tapped the start switch a few times, and there it was.
We had a torrential downpour the other night. My trunk has about an inch of water in it, even though the lid was closed. I wonder if I got some water in the switch.
1985 GL1200 Limited Edition
Welcome to the Site and Thanks for posting you results!!!
1 - 14 of 14 Posts
