Hello, my friend just got a 85 aspy, the po said it needed carb work. it had no power at all. well. we brought it home. startet at 8 pm, removed carbs off the bike, the choke was stick on all carbs so we had to separate them. carefully everything was taken apart. lots of fuel in gel state at the float bowls. removed all the rubber, the pilot screws on all carbs were 1 and 1/2 turn out on all carbs. cleaned the carbs bodies with lots of gasoline and sprayed carb cleaner trough the idle passages, cleaned the carb cleaner with more gasoline and then compressed air all around the carb bodies and every small hole. everything looking clean, the float valves were ok. got everything back together, using the haynes manual spects for a 85 non-california used 2 and 1/4 turn out on the carbs. bench synchronized them (all butterflies are same) and installed the whole thing back on the bike. carefully installed the choke and throttle cables. everything smooth, ok. fired her up.
the idle was at 1600 but very smooth. turned out the idle screw. and it only droped to 1500. warmed her up and that made any difference. the idle screw is almot 1 turn out of falling but is not stoping the carb thing anyway.
went for a short ride. pulled the throttle and what a difference, she had plenty of power just like my own 1200. rides very smooth idles very smooth. but too high though.
checking around.
the throttle is free and returns BUT. when you push the arms it will drop to 800 rpms its rly hard to push and all it will drop is to 800 rpm. on my 1200 if i can idle at 200 rpm just by using the scew. anyway.
checked the choke it is returning perfectly the exhaust has a little leak on the right pipe, haven't checked it out yet but it sounds and if you put ur hand unver it you will feel it.
I need some tips. whats the correct idle screw setting? if i remember right im using 2 and 1/4 on my 85 interstate and is working perfectly. i know the carbs rly need a rebuild but it may take some time for the parts to arrive, my friend has no more $$ for now and we wanna go to a rally this weekend so we want the bike to run a little better, well its running amazing is just the idle thing.
thanks in advance!!!
Sounds like the return spring on the throttle is bad or installed incorrectly. If you can push the throttle cam on the carbs and get a lowing of the idle the spring is not taking it back to full closed position. Something could be in the way, or a bad cable or bad spring or set up wrong.
Start the bike, loosen the throttle cable at the carbs, adjust the carbs, then secure the cable. Do this with the idle adjustment on the carb linkage in the mid position so adjustment can be gained later. And install a new throttle cable and springs.
Kit
Kit, thanks but on the 1200 its pretty hard to access the cables with the carbs in place. you need rly small hands and a rly small wrench =(
Solved. the left arm that moves the left side carbs was bent. fixed it and now it idles perfectly ;) thanks!
