1 - 20 of 35 Posts
Since I have owned the bike (84 Interstate). When I ride it and then park it . There is a sound that emits from somewhere on the bike like small amounts of air releasing. You know like wheee sound that fades. Pretty nice Huh could not think of a way to correctly state the sound in Onomonopia form so you will have to take the Wheeeeee fading air deal as whats happening.
Next time you hear this . . . . open the gas cap and see if it goes away quicker.
Okay I'll do that. Is there something I need to look for is it suppose to do that? I mean It's been doing it for three years now It does it maybe two or three times fairly quickly in succession then stops.
That would be my guess to , gas cap or rad cap.. But if for three year then gas cap would be my guess
Funny you say that but when I first heard it thats the first thing that came to mind( air brakes bleeding off). I just replaced the radiator cap I'll check the gas cap. I did notice the last time I opened the cap there was pressure in the tank.
lol gingerbreadman
Discussion Starter · #8 ·
Geez Gingerbreadman your avatar looks like a canamowing.:ROFL::ROFL::ROFL:
dont know what kind of vacuum system 1200 has, but maybe vacuum leak?
1987 GL1200 Interstate
Mine did that for years. It was the vacuum supply for the cruise control, I think. I don't even remember when it quit doing it.
A seal on the gas cap could also be to blame or even the seal on the sending unit.
I know i'm Geezing but i have never heard my bike to it !!!
Jim :ROFL:
Vintage Rider
I would say an intermittent vacuum leak.
every now and then mine will do the same type of sound, it will last about two seconds and about three or four times then it will quit, and wont hear it for a few more rides. if i turn the key back on it will quit, i have checked and the only thing i can find is the fuel pump, it will also quit if i pinch the gas line closed, so i guess it would be the fuel pump,but it was just replaced 4 months ago, doesnt affect how it runs or rides, still have good power and still avg 44.4 mpg at 75mph, so i dont worry too much about it.
Junior Grue
I've never heard of an Interstate with cruse control, must be an Arizona only option.:shock::ROFL:
Seriously it's your fuel cap. When you stop heat rises from the engine and guess where the fuel tank is. The cap is designed to hold a small amount of pressure and as the tank is heated at stop it vents, sometimes in short bursts.
Mine for sure had something to do with the cruise control vacuum supply as when I reached down and unplugged it, the song stopped.
My Interstate also has a tool tray and trunk mirror. And if you've never heard of an Interstate with cruise control, maybe you should try listening more.
Junior Grue
Hum, I might have been dreaming but I thought I remembered you saying that the start of your carburetor problems was your AFTER MARKET cruise control wearing the throttle shaft on one of your carburetors.:?
I had the same problem on my '78 gl1000. Turned out it was the turbo boost relief valve. I can't speak to the 1200 though. (we're no longer on terms)
It's the fuel cap. It's the fuel cap.
glhonda lmao
Discussion Starter · #20 ·
No No compressor. After listening to the reply's here I am thinking that it is the gas cap It has been hot here and I took it out the last time it was around 108 and I rode it for 40 miles or so just to check everything after my repairs and upgrades. I did notice when I took the cap off before I put gas in it did have some pressure build up. My Cruise control is nothing more then that throttle lock deal.
1 - 20 of 35 Posts
