Hi Ive just ordered fuse box as it looks like one brass connection on the back as worked loose that makes contact with the fuse as any member had this problem .The connection that plugs into the box looks ok. Is the back of the fuse box sealed or does it clip off or have I just pulled it apart? I all so need to replace the ignition switch complete can I get to it from under by the fork area or is it a complete top fairing removal and are the switches the same 1984- 1987. Thanks for any info and Great forum .Every time I fire it up theres always something needs doing! But it does look good I think it worth the time working on it.Cheers to every one.
