1 - 3 of 3 Posts
Steve,
I have a 1986 Aspencade and the instrument cluster works except for the speedometer. I tried changing drive gears and speed sensor cable to no avail.
Question is can I put a 1986 Gold Wing instrument cluster on my Aspencade?
Will it plug in if I use a regular speedometer cable?
Welcome to the Forum Wally
I don't know on that as its electronic to analog, should work but you would have to wire it yourself as the aspy harness is different.
Other side of the pond
Te gauges are a lot different. It could work out easier if you get hold of a used Aspencade cluster, they come up often enough on ebay.
1 - 3 of 3 Posts
