1 - 14 of 14 Posts
2021 Tour
Does anyone have or could send me a pinout on a LCD clock for 84-85 GL1200I. I have a manual with wiring but there are four pins on the clock and so far I have been unable to determine what wires go where. This is a bare bones installation . I don't have the wiring harness for the clock. Come on Dave0430 I know you can help. Thanks in advnce for any help.
There was a post on this some time last year.
I'll see if I can find it,
Try and use the forum search tool.
Wasn't able to bring it up. Maybe that person will happen by.
Maybe a moderator will be good and see this and change the title to include "wiring layout of pins needed"
WE USED TO BE ABLE TO DO THIS OURSELF.
Light Green/black (2 hooked together) is the light or keep alive. Red is the 12v Positive from the ignition switch and green is ground.
See which wire is hot with the Ignition switch off. Either the light green/black or the red wire. That one will be the keep alive. The one that is hot with the ign switch is the back light.
2021 Tour
Yea kinda had that figured out but what I need is which pins on the clock correspond to those wires. They aren't marked on the clock so I have no idea which is which.
Sorry my wiring diagram didn't show the pin out
2021 Tour
Discussion Starter · #8 ·
Trying to put a clock where there was none using an LCD clock from another Wing. The pins on clock are the problem. There are four and I know not which pin is associated with what function.
2021 Tour
Discussion Starter · #11 ·
Thanks to those that responded. I finally figured the pins out but back light bulb is shot and LCD clock is unreadable. It was a good idea for a moment. Might find another somewhere.
1 - 14 of 14 Posts
